Community Member
How to get translation pattern in CDR
Dear all, on my CCM 8.5 I use a lot of translation pattern to match external number (PSTN) with internal service/extensions.
There's a way to have this information (about the translation) in the CDR?
If I translate numberA and numberB to extension 555, I don't have any way now (from CDR/CAR) to know how many users call numberA or B
Enrico.
originalCalledPartyNumber
Text String
This field specifies the number to which the original call was  presented, prior to any call forwarding. If translation rules are  configured, this number reflects the called number after the  translations have been applied.
finalCalledPartyNumber
Text String
This field specifies the number to which the call finally gets  presented, until it is answered or rings out. If no forwarding occurs,  this number shows the same number as the originalCalledPartyNumber.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/8_5_1/cdrdef/cdrfdes.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
In the originalCalledPartyNumber they say:
"If translation rules are  configured, this number reflects the called number after the  translations have been applied. "
so isn't possible right?
Community Member
I am also have the same issue
I am also have the same issue. Does anyone have a solution for this issue?
1052
