Community Member
how to i setup this auto attendant in cisco unity ?
how do i setup an auto attendant in cisco unity server to provide a list of options to the caller eg.
press 1 to reach sales.  ( dials sales extension )
press 2 to reach marketing  ( dials marketing extension )
1 ACCEPTED SOLUTION
U want to setup call handlers, and with that you can have keypad options to go to different call handlers and so forth.
I will really recomend you to seeks for book on this matter, otherwise will be a little hard to explain with no experience in the field
Please Kudos/rate if this help!
Community Member
if anyone can point me in the right direction as to what feature should be used in cisco unity
There are already plenty of threads with step by step configs and pointers on CSC as I already told you in another thread, you just need to search.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
103
