How to implement 5 digits outgoing dialing?
Call Manager 4.X
The customer have a lot of business contacts in DC area, so they want to speed the dialing. For example, most of their phone numbers in 202-313-XXXX range, so the user wants to dial 5-XXXX instead of 91-202-313-XXXX to reach their contacts.
How to configure the CallManager to apply this feature?
Thanks for your help!
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: How to implement 5 digits outgoing dialing?
You can use translation patters to do this...
Go to CCMadmin>Route Plan.>xlation pattern.
Click add a new xlation pattern.
In the xlation patter field enter 5XXXX.
In the partition fied add the appripriate partiton, make sure that the css of user phones can reach this partition.
In the CSS field enter the apripriate CSS. Make sure the CSS has access to the partition of the Xlation pattern
scroll down to Called party xformations.
In the called party xformation mask..enter the full number eg 91202313XXXX
HTH, Pls rate useful posts
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
use translation patterns to modify 5.XXXX to 91-202-313-XXXX, fairly easy
java
if this helps, please rate
java
www.cisco.com/go/pdi
VIP Super Bronze
119
