06-19-2008 04:37 PM - edited 03-15-2019 11:24 AM
HELLO EVERYBODY
I need to implement DISA (Direct Inward System Access) on the callmanager express 4.0. Does anybody know what I need to make the DISA work.
Walter
06-19-2008 08:14 PM
It is not an immediate configuration, as you need scripts with PIN to protect access. What are you exactly trying to do ?
06-20-2008 07:10 AM
HI Bevilacqua
I need to configure that the user call an DID and authenticate via an account number and PIN.
what I've done upto now is the configuration on the callmanager express.
1. authenticacion and authorization:
aaa new-model
aaa authentication login default local none
aaa authentication login h323 local
aaa authorization exec h323 local
aaa session-id common
2. Username and password: 1000/1000 y 1001/1001
username 1000 privilege 0 password xxx
username 1001 privilege 0 password xxx
3. Dial-peers where I defined the DID and
service. I saw some configuration application instead of service on the dial-peer but on the dial-peer voice POTS is the only part where I can assigne the clid_authen_collect.
dial-peer voice 25 pots
description TCL SCRIPT
service clid_authen_collect
incoming called-number 24131623
direct-inward-dial
port 0/0/0:15
The DISA does not work but I think, this is because I do not have the SCRIPT load on the callmanager express.
Could you tell me if the path followed is correct?
Do you know how the make a script in order to load the callmanager?
REGARDS
Walter
06-20-2008 07:18 AM
seems fine. The script is embedded in IOS. Do "debug call application script" with "term mon" to see what is going on.
08-05-2008 02:43 PM
I had problems with that script too. I ended up having to make a new script for DISA, it just uses a pin but maybe you can edit it to do what you want:
application
service disa flash:DISA.tcl
param set_the_pin 1234
dial-peer voice 10 pots
service disa
incoming called-number 1465
no digit-strip
direct-inward-dial
port 0/0/0:15
08-06-2008 03:42 AM
I also want do learn how to config it in CCM and IPCC express?
Any one who can give me some document or URL?
THanks
