04-15-2010 06:39 AM - edited 03-15-2019 10:17 PM
As of Right now we can only initiate 4 calls using the conferance feature, is there a way to increase the number of people that can be on at the same time?
Solved! Go to Solution.
04-15-2010 06:49 AM
This has been asked PLENTY of times before, please search NetPro for answers before posting.
Change this parameters depending on what kind of conference you want
CUCM Service Parameters
Maximum Ad Hoc Conference
Maximum MeetMe Conference Unicast
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
04-15-2010 06:54 AM
Yes. In the Call Manager service parameters you can modify the "maximum ad hoc conference" parameter. From the online help:
This parameter specifies the maximum number of participants that are allowed in a single Ad Hoc conference. The value of this field depends on the capabilities of the software/hardware conference bridge. The maximum number of conference bridge participants for typical conference bridges follow: Software Conference 64; Cisco Catalyst WS-X6608: 16; Cisco Catalyst 4000: 16; and NM-HDV: 6. Setting this value above the maximum capacity of the conference will result in failed entrance to a conference bridge if you try to add more ports than the specific conference bridge configuration allows.
This is a required field.
Default: 4
Minimum: 3
Maximum: 64
Note that with later ISRs/IOS, I believe you can get 8 parties in a single conference.
HTH.
Bill
04-15-2010 06:49 AM
java
04-15-2010 06:54 AM
Default: 4
Minimum: 3
Maximum: 64
HTH.
Bill
04-15-2010 07:17 AM
Thank you for the replys, I found the setting and have changed it already. Sorry for not searching first, this is my first post and plead ignorance.
Thank you very much
04-15-2010 07:29 AM
Not a problem, just remember that NetPro is a great resource because of that. Many of the questions you might have, are already in threads, and you just need to take 5 minutes to search and you'll probably end up with a lot of hits in your search.
I'd say around 80% of common questions and problems are already in some threads.
java
