how to install CallManager 4.3 in VMware?
hi all,
is there some specific steps to follow in order to install CallManager 4.3 (Windows 2003 Server Based) in VMawre environement?
Thx in advance,
Re: how to install CallManager 4.3 in VMware?
Take a look here: http://www.blindhog.net/cisco-install-call-manager-4x-with-vmware/
OS requirements are likely different but this will give you a good starting idea.
Hailey
Please rate helpful posts!
i need steps for windows 2003,  win 2000 does not support CallManager,
i've already tried the link below, but it did not work finaly.
Super Bronze
Do you have a set of Cisco OS CDs with your CM4.3 media? What version are they?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
yes i do have cisco OS CDs: Windows 2003.1.2A (E)
but when i try to boot Vmware with this OS, a message displays indicating that i need an MCS Hardware.
Super Bronze
Well - I can get 2003.1.2A to install on my setup.
When you define the VM, set these params:
OS : 2003 Standard
HDD : 72GB, IDE
CPU : 1 CPU
Mem : 1024Mb
Aaron
Red
You have two options to install "Cisco OS 2003" (basically Windows 2003).
1) Use original Cisco OS 2003 DVD.
Please note that VMWare is only supported in later version.  And it might require specific VMWare edition/version (e.g. ESXi 4.0).
2) Use generic Windows 2003 DVD and apply regitry patch (attached).
This is my preferred option.  Because:
a) I can install it on any VM software.
b) It's quicker to install
c) I can use volume license so no activation is required.
Michael
http://htluo.blogspot.com
1393
