How to integrate a Communication Manager with Unity Express
In central site a have a CME 4.1 with Unity Express, in one remote site I have CM 4.1(3)with a few phones I want to asign voice mail to these user by means of unity express
Marwan ALshawi
hi Filiberto
the following link will guid u step-by-step to achieve it
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a0080289ef0.shtml
good luck
if helpful Rate
gogasca
Level 10
Level 10
We will have an issue here.
CUE supports either CCM or CME.
You can send the VM call to CUE across a trunk and user will go to VM, you can setup accounts there no problem, but MWI will not work at all. In CCM 4.X we dont support SIP unsolicted notify for MWI.
Hi gogasca!
thanks for that info
regards
Marwan ALshawi
hi Filiberto
good luck
if helpful Rate
