How to know firmware version for all devices in a CUCM cluster
We need to know the firmware version used for each one of the devices in a CUCM cluster (version 6.1)
Anybody know if we can get this info for example wit the BAT?
Thanks and regards,
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hi Alberto,
You can also check the phone load using the following command from the CLI/SSH of the call manager.
show risdb query phone
Please log the session to a file as the entire output will be dumped on the terminal. Then open the file using MS Excel to be able to view the data in a readable format.
HTH,
Jagpreet Singh Barmi
You typically need to use a 3rd Party application to do this.
There are many that can do basic device information gathering, but if you are looking for a complete endpoint solution that scales to 10,000+ devices you should have a look at PhoneView from UnifiedFX (http://www.unifiedfx.com)
Stephen
Hi Alberto,
HTH,
Thanks Jagpreet, that´s just what I was looking for.
Alberto
372
