Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
tka
How to know th Devices/Lines using a certain CSS
I want to delete a CSS, but before I would like to know which devices /lines is using that CSS . Is there a way to do that ?
Thanks.
Silver
Re: How to know th Devices/Lines using a certain CSS
Look for "dependencies" On the top right side of the same page. You need to remove those dependencie before deleting the CSS.
MK
Hall of Fame Super Red
Hey Ramzi,
Just to add another method to the good tips from MK (+5 ponts MK
Go to > Device > Phones > Find and List Phones > Find phones where> desired CSS > Search >
this will produce a list of all phones using this Calling Search Space.
Cheers!
Rob
Silver
Thanks Rob, I appreciate your kindness :-)
MK
tka
Hi Rob,
You're right . HOWEVER, This could not give the Lines using the CSS. Am'I right ?
best regards,
214
