How to know Unified communication Manager express is loaded or not on 1861router
Hi Fiends,
I bought this Cisco 1861 a few weeks ago, We have been a bit busy so only unboxed and turned it on today, Can anyone suggest me how to confirm whether  Unified communication Manager express &  unity expres  is installed or not on router how to check it pls suggest
I did check flash but I can’t understand
Melbourne1861#sh flash:
-#- --length-- -----date/time------ path
1         2898 Aug 27 2009 05:28:34 +00:00 cpconfig-18xx.cfg
2      2324992 Aug 27 2009 05:28:50 +00:00 cpexpress.tar
3         1038 Aug 27 2009 05:29:00 +00:00 home.shtml
4       115712 Aug 27 2009 05:29:10 +00:00 home.tar
5      1697952 Aug 27 2009 05:29:28 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
6       415956 Aug 27 2009 05:29:40 +00:00 sslclient-win-1.1.4.176.pkg
7     34148116 Nov 5 2009 01:09:06 +00:00 c1861-spservicesk9-mz.124-20.T4.bin
89464832 bytes available (38719488 bytes used)
Pls provide me a way for check it
  • IP Telephony
1 ACCEPTED SOLUTION
Re: How to know Unified communication Manager express is loaded
The CME is a feature that comes with different IOS series, so if you can send us a copy of show version we will be able to find if your IOS has CME or not, also you can go to global configuration mode and try to type "telephony-service" if the router takes the command is because you have CME and if you would like to know the version use "Show telephony-service" at exec mode.
To know if you have CUE we will need the output of the show diag because CUE is an special card or module in the router.
Please rate this post if was helpful
Walter Solano
Walter Solano
Hello Walter Solano,
Thanks for your reply,
I am verry veery happy for your reply, I think we have Unified communication Manager express  on Cisco 1861 router, please let me know & confirm me i have attched detail of version & Telephony..
Vikrant
169
