How to lock/unlock IP Phone CUCM 7.1
In CUCM 7.1 setup do it possible to lock/unlock ip phone without third party software, myself suggest a solution for lock/unlock with extension mobility, do please suggest the various workaround for lock/unlock the IP Phone
1 REPLY
Re: How to lock/unlock IP Phone CUCM 7.1
We do not provide any mechanism to lock phones, the only similar functionality is via EM as you mention but you really don't lock the phone.
You just force the user to use a UDP to change the calling privileges. But any user can still go and press the buttons and play with the phone.
If you need to lock the phones and make sure no one can do absolutely anything with it without unlocking it, look for 3rd party apps.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
798
