05-14-2010 12:59 AM - edited 03-15-2019 10:45 PM
Does anyone knows how to modify Audio bandwidth parameter in Locations via SOAP? Is there any example?
Thanks in advance.
Solved! Go to Solution.
05-14-2010 01:30 AM
You would need to issue a SOAP updateLocation request, as per the AXL spec.
The interface spec is documented here: (http://developer.cisco.com/web/axl/docs - pick the appropriate spec for your CM version)
Are you new to SOAP, or do you have some existing SOAP scripts you use for another purpose? If so what language?
Aaron
Please rate helpful posts...
05-14-2010 01:30 AM
Aaron
