Community Member
How to? MoH @ Branch Router, IOS15, Multiple Streams
Hello
I can't find anything that says this can be done or gives an hint that configuration will support it.
On my CUCM (8.6), I am using multiple audio sources for Multicast MoH. The sources are divied up based on MRGL assignments within DN settings.
I would like to also stream multicast from flash at a branch router.
All of the examples and discussions I've seen show a single file being streamed.
I know that IOS 15 allows for 6 MoH sources (one "system" and 5 "group") to be streamed when the router is a CME router.
Can these multiple streaming resources be set up when CME is not being used?
I understand SRST has to be enabled no matter what; the thing I'm stuck on is if it's possible to differentiate source A from source B.
When configuration CUCME (9.1 on IOS 15.2(4)M), it is possible to group phones together and point them at a particular MoH source for that group, but when using router flash for getting multicast MoH to remote CUCM-controlled phones, the ephone information isn't in the router's configuration...so there is nothing to assign to a group!
So...is it possible with IOS 15 in call-manager fallback mode to specify multiple MoH sources? If so, how do you do it, and align it to the source id CUCM presents to the IP phone through it's MRGL?
Thanks in advance
Everyone's tags (5)
1- All MOH should be installed on your flash:
2-Your have to assign five multicast IP addresses to be used on your CME which are not used on your network.
3-Voice moh-group which identify the moh stream , as example below 1 ,2,3,4,5. Then configure multicast ip ,you can also define range of your extension
Please find the below example:-
telephony-service as you know (call-manger-fallback or can use telephony-service for many feature)
telephony-service
moh alaska.wav
Moh multicast 239.1.1.1 port 16384 route 10.1.4.31 10.1.1.2
voice moh-group 1
description this moh group is for sales
moh flash:/hello.au
multicast moh 239.1.1.1 port 16386 route 239.1.1.3 239.1.1.3
extension-range 1000 to 1999
extension-range 2000 to 2999
extension-range 3000 to 3999
extension-range A1000 to A1999
voice moh-group 2
description (not configured)
moh flash1:/minuet.au
multicast moh 239.23.4.10 port 2000
extension-range 7000 to 7999
extension-range 8000 to 8999
voice moh-group 3
description This is for marketing
moh flash2:/happy.au
multicast moh 239.15.10.1 port 3000
extension-range 9000 to 9999
voice moh-group 4
moh flash:/audio/sun.au
multicast moh 239.16.12.1 port 4000
extension-range 10000 to 19999
voice moh-group 5
moh flash:/flower.wav
multicast moh 239.12.1.2 port 5000
extension-range 0012 to 0024
extension-range 0934 to 0964
Thank you
Please rate all useful information
Community Member
Here is the point I am confused on: If the phones are controlled/provisioned by CUCM, how does the router know what extension is in what group? Under CUCME or CUCME+SRST, the router knows extension numbers because of SCCP or SNAP. When the phones are controlled by CUCM, the router is just a... router. It has no intelligence about the phones. So, in effect, MoH on a branch router simply turns the router into a multicast transmitter.
Here is what I am thinking, after reading more documentation... I can't lab it yet, but if you or someone else can confirm this will work or not, I would appreciate it.
Under "Restrictions" at http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1022742 it says : "
Each MOH group must contain a unique flash media file name, extension numbers, and multicast destination. ....."
But, Step 7 (the extenstion-range command) is listed as optional :
"(Optional) Identifies MOH callers calling the extension numbers specified in a MOH group. Extension number must be in hexadecimal digits (0-9) or (A-F). Both extension numbers (starting extension and ending extension) must contain equal number of digits. Repeat this command to add additional extension ranges."
What that says to me is that the extension ranges are not required, and that basically I can configure 5 groups (in addition to the system default source) with Multicast IP & Port numbers that match what CUCM will tell the phones, and it will work from there.
Is that accurate?
Hello
so you problem how can you recoginize the ephone-dn?. This problem you have , because you have call-manager-fallback/ If you us Telephony-service you can manage all extenions , because after the fallback all phones will be found on the show with dn. After that you can control.Use as the below , and test;-
telephony-service
sdspfarm units 3
sdspfarm transcode sessions 4
sdspfarm tag 1 SC_MTP
sdspfarm tag 2 SC_Xcoder
srst mode auto-provision all
srst ephone template 1
srst dn template 1
srst dn line-mode octo
max-ephones 10
max-dn 10
ip source-address 10.1.1.1  port 2000
time-zone 42
time-format 24
voicemail 2200
mwi relay
max-conferences 8 gain -6
moh music-on-hold.au
transfer-system full-consult
transfer-pattern .T
create cnf-files
Thank you
1242
