How to move a virtual machine between datastores on UCS
rcrumm_2
Level 2
Level 2
HI,
How Can I move a virtual mahcine between datastores?
Randall
Or if you are asking how you move it (but not necessarily migrate it while it's live):
Option 1 - Take a backup, build a new server from the appropriate OVA in the new datastore, and then restore the backup to the new VM
Option 2 - Shut it down, browse the datastore using vSphere client, and copy the VM and all the files to the new location.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
5 Replies 5
Chris Deren
Do you have vCenter.
Chris
I am using the vsphere client
randall
What you're asking for requires vCenter, the feature is called Storage vMotion and you also need to have a shared storage to do so.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Aaron
Thanks Aaron,
Option 2 worked, but I had to remove and add to inventory.
