Community Member
How to negate "debug mmoip send email XXXXX"
I need help in negating "debug mmoip send email XXXXX" if possible please.
I have tried , "no debug mmoip send email XXXXX" and "undebug mmoip send email XXXXX" - Router accepted the commands. But when I issue "show debug" command the output still shows "Debug email send tranactions to: XXXXX".
Issuing "undebug all" doesnt have any effect on this. I tried to change email address to see if it chnages , i.e, tried debug mmoip send email YYYYY". But the "show debug" output still shows the old email "Debug email send tranactions to: XXXXX".
cisco AS5300 , ios version 12.3
Sivaji
Green
Can you try
no debug fmail client
The ref manual seems to say that
debug fmail client
debug mmoip send mail xxxx
work in parrallel
http://www.cisco.com/en/US/docs/ios/12_3/debug/command/reference/dbg_l1g.html#wp1049638
Alex
Regards, Alex. Please rate useful posts.
Community Member
Thanks for your reply Alex,
fmail is not recognised by this box at all.
thanks,
Sivaji
Green
I cant find any bugs for this.
Could it be that there is someting in the config that is permanently logging to syslog etc.
Alex
Community Member
I have checked the config for any related configuration already. It is defenitely not coming up due to a confid apart from the debug as I far as I can see.Not sure what it could be.
Thanks for your time.
thanks.
Sivaji
480
