03-27-2012 06:12 AM - edited 03-16-2019 10:19 AM
We are running UCCX 7 as a proof of concept project for some of our smaller call center campaigns and one of the features we have been asked about is how to let callers know their position in the queue.
Does anyone have any advice on how best to do this?
Jason
Solved! Go to Solution.
03-27-2012 06:33 AM
Jason please refer to the below discussion. I have a copy of a script in there that shows how to notify caller of their position in queue. This should be a good visual for you to follow and it is built in UCCX 7.
https://supportforums.cisco.com/message/3577644#3577644
03-27-2012 07:00 AM
No problem. Let me know if you get stuck anywhere or have any other questions.
03-27-2012 06:18 AM
Hi Jason,
The Get Reporting Statistic step is only available with Cisco Unified CCX packages.
You can use this step to view the current state of the Cisco Unified CCX system or to report back to a
caller such information as current wait duration, position in queue, and expected wait time.
The system bases the expected wait time calculation on the number of agents in reserved, talking, and
work states for this CSQ, the call’s position in the queue, and the average call duration for this CSQ.
Average call duration of a CSQ is the average time agents spend in Reserved, Talking, and Work states
while handling a call from this CSQ.
Please refer the page 208 in the below guide.
Hope it helps.
Anand
Please rate helpful posts, by clicking on the stars below the right answers!!
03-27-2012 06:33 AM
03-27-2012 06:54 AM
Hi Andrew,
This looks like the sort of thing I am looking for.
I will have a go using this and let you know if it does the trick.
Thank you, much appreciated
Jason
03-27-2012 07:00 AM
03-30-2012 03:28 AM
Hi Andrew,
I've had a play around with teh scrip to tailor it to my queue and it has worked perfectly so many thanks for this.
Jason
