05-14-2014 03:28 AM - edited 03-16-2019 10:47 PM
is there a way to do a factory reset remotely?
i had a look on the terminal via ssh but cant find anything
thanks
Solved! Go to Solution.
05-14-2014 07:58 AM
Only if you have CUCM 10.X there's an option for that.
05-14-2014 07:58 AM
04-14-2015 01:55 PM
Hi Jaime, could u plz tell me how to do it on CUCM 10.X as i have already CUCM 10.5(2).
04-14-2015 02:37 PM
It's an option under BAT
04-15-2015 12:58 AM
Hi Gents, I tried this feature today but unfortunately it is only supported on limited phone types, i think all the common 79XX series are not supporting this cool feature.
it seems that we have to go to a 3rd party tools, i'm currently trying one tool and will get back to you with findings.
04-15-2015 09:36 AM
seems like we have only these phones support this feature
Product | Protocol | Feature | Parameters |
Cisco DX650 | SIP | Remote Wipe | |
Cisco DX70 | SIP | Remote Wipe | |
Cisco DX80 | SIP | Remote Wipe |
03-30-2018 07:33 AM
Hi Ahmed
How did it go with the 3rd party tool? We are trying to wipe our 79xx phones as well
04-14-2015 03:36 PM
Here the doc you can find how to do to factory rest
In Unified Communications Manager, some phones can be wiped remotely. When a remote wipe is performed on a phone, the operation resets the phone to its factory settings. Everything previously stored on the phone is wiped out.
If a phone supports the Remote Wipe feature, a Wipe button appears in the top right hand corner.
through BAT
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmcfg/CUCM_BK_C95ABA82_00_admin-guide-100/CUCM_BK_C95ABA82_00_admin-guide-100_chapter_01001000.html#CUCM_TK_RE4D02BE_00
You can through document if required
let me know if this help
Br,
Nadeem Ahmed
