How to perform factory reset remotely on Cisco 9951
is there a way to do a factory reset remotely?
i had a look on the terminal via ssh but cant find anything
thanks
Jaime Valencia
Only if you have CUCM 10.X there's an option for that.
java
if this helps, please rate
7 Replies 7
Jaime Valencia
java
Hi Jaime, could u plz tell me how to do it on CUCM 10.X as i have already CUCM 10.5(2).
It's an option under BAT
java
Hi Gents, I tried this feature today but unfortunately it is only supported on limited phone types, i think all the common 79XX series are not supporting this cool feature.
it seems that we have to go to a 3rd party tools, i'm currently trying one tool and will get back to you with findings.
seems like we have only these  phones support this feature
ProductProtocolFeatureParameters
Cisco DX650SIPRemote Wipe
Cisco DX70SIPRemote Wipe
Cisco DX80SIPRemote Wipe
Br, Nadeem Please rate all useful post.
Hi Ahmed
How did it go with the 3rd party tool? We are trying to wipe our 79xx phones as well
Here the doc you can find how to do to factory rest
In Unified Communications Manager, some phones can be wiped remotely. When a remote wipe is performed on a phone, the operation resets the phone to its factory settings. Everything previously stored on the phone is wiped out.
If a phone supports the Remote Wipe feature, a Wipe button appears in the top right hand corner.
through BAT
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmcfg/CUCM_BK_C95ABA82_00_admin-guide-100/CUCM_BK_C95ABA82_00_admin-guide-100_chapter_01001000.html#CUCM_TK_RE4D02BE_00
You can through document if required
let me know if this help
Br,
Nadeem Ahmed
