Community Member
How to play voice when a call is transferred?
We have a Cisco Unified Communication Manager 7.0.1.11000-2 installation.
When a citizen calls an employee and the employee need to transfer the call to another employee, we often experience that the citizen thinks the call has been cut when the first employee tries to transfer the call to another employee that currently are busy with another call.
Is there any way that we can activate some kind of message or music so the citizen knows that the call has not been cut, but can hear that the line is busy and waits to get through?
Kind regards,
Carl-Marius
Everyone's tags (1)
2 ACCEPTED SOLUTIONS
Community Member
Re: How to play voice when a call is transferred?
It seems, that you need to configure MoH audio source. More information: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmfeat/fsmoh.html#wpxref59089
Make sure the MRGLs for the GW has an MOH server and you set a Network Hold MOH Audio Source for the devices.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
java
java
Community Member
Hi dfokin and javalenc,
You were right! - It works when MOH is activated on the phone numbers
Thank you for your help!
Kind regards,
Carl-Marius
287
