How to prefix a call depending on Calling Party Number or FXS port?
Depending on what FXS port makes the call, how can I prefix the called party number in order to route the call as described below?:
FXS port 1 should be prefixed with a digit(s) so it can be routed to Location B, PSTN breakout or to a phone on this location
FXS port 2 should be prefixed with a digit(s) so it can be routed to location C PSTN break out.
Topology:
3 physical locations.
Location A:
Cisco router with 8 FXS ports
Location B: Cisco router with FXS ports or PRI to a PBX, and PSTN gateway
Location C: CUCM sentralized CUCM cluster and PSTN gateway
1 ACCEPTED SOLUTION
Ok I assuming your using h323
This way you can enable caller ID I. Each FXS port and assigne a unique number for each fax for example let's say you want pt prefix 8 for call from fax in port 0/1
voice-port 1/1/3
description ***>FAX
station-id name SiteXXX_FAX
station-id number 5588
caller-id enable
Translation pattern to prefix 8
Voice translation-rule 1
Rule 1 // /8/
Voice translation profile fax1
Translate called 1
Try to make a pots inbound  dial peer to prefix 8
dial-peer voice 10 pots
Translation-profile incoming fax1
Answer-address 5588
Make sure that you have a VoIP dial peer to send called numbers start with 8 to CUCM
Hope this help
1 REPLY
voice-port 1/1/3
description ***>FAX
caller-id enable
Rule 1 // /8/
Translate called 1
Answer-address 5588
Hope this help
410
