How to program CUCM 6.12 to a SR140 software-based eFax server via FoIP?
Has anybody done a integration from a CMM/CUCM 6.12 to a eFax sever via T.38 protocol, if so any info would be helpful and appreciated..TIA  ThomasNH
Re: How to program CUCM 6.12 to a SR140 software-based eFax serv
Yes I have. In my particular setup I have a trunk created from my cluster to our eFax server. On my MGCP controlled gateways I had to change the default package that loads when configuring MGCP to "mgcp default-package fxr-package" which is the package used when dealing with facets of faxing. Then you need to do a no mgcp and then mgcp for it to take effect. On my H323 gateways its just a bit of configuration on the gateway and some dial peers.
On your gateways, are you using MGCP or H323 for inbound/outbound calls?
We're using MGCP for in/outbound calls. I am talking to the eFax vendor, I was surprised to learn that they're using wink start on the CO trunk. Have you installed this scenario through a PRI T1? I am trying to leverage the existing Telco trunks on CMM to save money down the road. Question: How is the link between CMM and eFax configured, it is done via an IP address, I still can't see how this is implemented? Any ideas, I would greatly appreciate it. I am coming from a Nortel environment and we used ISL trunks to do the integration. Thanks for your suggestions though, I'll setup those ideas up in our Lab before rolling it into production. TIS Thomas NH
If you navigate to Device, then Trunk then click the Add New button you will have options to create trunks. In my scenario the eFax venfor wanted it to be an intercluster trunk, i questioned that but whatever it works. Then you create a route pattern for the number(s) that you want to traverse that trunk into the eFax server by selecting the trunk in the drop down list of the Gateway/Route List* option.
When you create the trunk you specify the ip address of the eFax server where it shows Server 1 IP Address/Host Name*
And I am connected to the PSTN with PRI's.
Tracy,
Thanks for clarifying the integration part. I'll post my findings/configuration when Lab is up and running.
TIA,
Thomas NH
Tracy,
FYI -
The FoIP integration on CUCM from a SIP tunk perspective worked great, we're in business! Thanks for clarifying the design concept.
TIA,
Thomas NH
Great!
980
