Community Member
How to Rebuild a Publisher Server for Cucm 6.1.(2)in case of emergency
How to Rebuild a Publisher Server for Cucm 6.1.(2)in case of emergency or disaster or publisher is not booting  or may filesystem is corrupt.
Well i have a production cluster built on 6.1.(2)1124-1  with 4 subscriber and a tftp server all on MCS 7845- I1  hardware servers. At time i found two of my subscribers hardware failed and we succeefully rebuild it because only the SCSI controllers were defective.  Keeping this in view what if my publisher servers fail and HDD is defective and it is not coming up or reason stated above.
How Should i go ahead to rebuild in the least possbile time frame ?
Everyone's tags (3)
1 REPLY
Re: How to Rebuild a Publisher Server for Cucm 6.1.(2)in case of
Replacing a Single Server or Cluster for Cisco Unified Communications Manager Release 6.1(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_1/cluster/clstr611.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1775
