09-16-2009 08:14 PM - edited 03-15-2019 07:47 PM
Hi all,
How to record voice conversation on the IP phone?
Appreciate any response. Thank you.
09-16-2009 10:21 PM
Attached is a link explaining topics off how to record a call and monitoring
it for CUCM 6.0, please refer to it
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_0_1/ccmfeat/fsmr.
html#wp1047586
Also,
Unity has the Record Live but Cisco does not support
this feature because it was locked down to only work with a couple different
switches
check in unity tools for live record
09-17-2009 06:14 PM
Hi Virender,
Thank you for your info.
That docs is for CUCM 6.0. Currently I'm using Call Manager 4.2.
Is there a way for me to do it in CM 4.2?
09-17-2009 06:52 PM
the only Cisco supported tool to record calls within the Cisco CallManager is CRS.
Here is a link with all the information regarding this feature:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a00801
a62a8.shtml
third party applications you can lookout for,
Voice Print VoIP
http://www.voiceprintonline.com/record-voip-ip-phone-recording.asp
http://www.datavoice.spescom.com/content.asp?baseMenuID=4&menuID=141
btw, did you get chance to check unity live record I mentioned.
10-01-2009 01:27 AM
Hi Virender,
Thank you. Currently I don't have chance to check unity live record. I will try it later.
Thank you very much for your help.
regards,
