How to refuse call?
Hi all, we are running CCM 4.2 with 7911 phones and I would like to ask, if it is possible to deny call, when its ringing (like on mobile phone). I just found out that there is a DND button (but probably on higher versions of CCM) and anyway DND is not exactly refusing of call because as far as I understand it also turn off ringing. Do somebody know how to refuse calls when they are ringing? Thanks very much.
Silver
Re: How to refuse call?
You could use IDIVERT and forward to VM?
Silver
You can do an iDivert (immediate divert) to send the call directly to voicemail.
Re-configure your softkey template (Ring In) to add it to a phone.
As far as I know there isn't a softkey that deny's a call though..
Please rate useful posts....
Thx, but we dont use voicemail and this button if I add it doesnt do anything when phone is ringing. Is there a chance to configure it on CUCM by some workaround - for example somehow configure some black-hole instead of voicemail on CUCM?
Idivert uses the VM profile, there is no way to modify the behavior.
you can configure a dummy profile and they should get busy
DND as you mention is standalone feature on linux appliance, on windows IPMA is required
java
if this helps, please rate
java
www.cisco.com/go/pdi
Pls, can you give short advice how to adjust such dummy profile? I havent ever operate with voice-mails and I will configure it on production system. Thanks a lot.
133
