How to regenerate security certificates? CUCM 6.1.3
Company has a call manager with 3 nodes on version 6.1.3:
- NODO1: 10.102.224.254
- NODO2: 10.102.224.253
- NODO3: 10.102.239.20
From S.O. web can be seen that some certs are going to expire. We have received a warning via e-mail. And we have checked opening certifications that expiration date is about to happen.
This is the security mode configuration:
Service parameters --> Publisher --> Call Manager-->Security Parameters
Cluster Security Mode: 1
CAPF Phone port:3804
CAPF Operation expires in (days):10
Enable caching: false
Certificates that are going to expire are the following:
CallManager_pem
CallManager_der
CAPF_pem
CAPF_der
CAPF-e09c40eb_pem
CAPF-e09c40eb_der
ipsec_cert_der
ipsec_cert_pem
NODO1_der
NODO1_pem
tomcat_cert_der
tomcat_cert_pem
At publisher, it can be seen no CTI file,
show itl
Executed command unsuccessfully
No valid command entered
There is only a CTL file, and it´s the following:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.02.19 17:47:46 =~=~=~=~=~=~=~=~=~=~=~=
show ctl   //Note: at the following file, some digits of the "SIGNATURE" have been changed with "*". And some name. Nothing else.
Length of CTL file: 5946
Parse CTL File
Version:          1.2
HeaderLength:          304 (BYTES)
BYTEPOS          TAG                    LENGTH          VALUE
3          SIGNERID          2          117
4          SIGNERNAME          56
5          SERIALNUMBER          10
6          CANAME          42
7          SIGNATUREINFO          2          15
8          DIGESTALGORTITHM          1
9          SIGNATUREALGOINFO          2          8
10          SIGNATUREALGORTITHM          1
11          SIGNATUREMODULUS          1
12          SIGNATURE          128
8d  e3  61  8a  d9  8  e  a3
8d  5b  82  6f  51  81  a3  1b
e2  fe  e5  57  66  f7  ab  54
f  69  fb ** 72  bf  3f  a1
ee  ea  a3  fb  b5  80  0  af
74  20  ac  b  92  b0  c5  fd
fa  f6  6e  52  c3  90  25  e1
2a  ** 83  f0  ee  4f  d3  9b
2e  6b  c4  4d  45  79  40  41
f2  b7  3  7e  7f  7a  **  b4
76  cc  45  e2  52  b1  4e  63
74  b1  a7  d8  36  97  22  47
8a  80  63  88  67  7e  7a  8d
2d ** eb  24  57  7b  c2  74
cf  4  bb  9d  dd  b1  a  a
e7  a9  5a  58  88  0  3f  67
14          FILENAME          12
15          TIMESTAMP          4
CTL Record #:1
1          RECORDLENGTH          2          1186
2          DNSNAME                    1
3          SUBJECTNAME          56          cn="SAST-ADN597e8314        ";ou=IPCBU;o="Cisco Systems
4          FUNCTION          2          System Administrator Security Token
5          ISSUERNAME          42          cn=Cisco Manufacturing CA;o=Cisco Systems
6          ISSUERNAME          10
7          PUBLICKEY          140
9          CERTIFICATE          902
10          IPADDRESS          4
This etoken was not used to sign the CTL file.
CTL Record #:2
1          RECORDLENGTH          2          1180
2          DNSNAME                    1
3          SUBJECTNAME          56          cn="SAST-ADN592dfe14        ";ou=IPCBU;o="Cisco Systems
6          ISSUERNAME          10
7          PUBLICKEY          141
9          CERTIFICATE          895
10          IPADDRESS          4
This etoken was used to sign the CTL file.
CTL Record #:3
1          RECORDLENGTH          2          765
2          DNSNAME                    15          10.102.224.253
3          SUBJECTNAME          13          cn=NODO2
4          FUNCTION          2          CCM+TFTP
5          ISSUERNAME          13          cn=NODO2
6          ISSUERNAME          8
7          PUBLICKEY          140
9          CERTIFICATE          541
10          IPADDRESS          4
CTL Record #:4
2          DNSNAME                    15          10.102.224.254
3          SUBJECTNAME          13          cn=NODO1
5          ISSUERNAME          13          cn=NODO1
6          ISSUERNAME          8
7          PUBLICKEY          140
9          CERTIFICATE          541
10          IPADDRESS          4
CTL Record #:5
1          RECORDLENGTH          2          982
3          SUBJECTNAME          43          cn=CAPF-e09c40eb;ou=AREA TIC;o=NOMBREX
4          FUNCTION          2          CAPF
5          ISSUERNAME          43          cn=CAPF-e09c40eb;ou=AREA TIC;o=NOMBREX
6          ISSUERNAME          8
7          PUBLICKEY          140
9          CERTIFICATE          698
10          IPADDRESS          4
CTL Record #:6
1          RECORDLENGTH          2          764
2          DNSNAME                    14          10.102.239.20
3          SUBJECTNAME          13          cn=NODO3
5          ISSUERNAME          13          cn=NODO3
6          ISSUERNAME          8
7          PUBLICKEY          140
9          CERTIFICATE          541
10          IPADDRESS          4
The CTL file was verified successfully.
Certificates at publisher are the following:
admin:show cert list own
tomcat
ipsec
CallManager
CAPF
ipsec-trust/NODO1.pem
ipsec-trust/NODO1.der
ipsec-trust/c92d8a04.0
CallManager-trust/CAP-RTP-001.pem
CallManager-trust/CAP-RTP-002.pem
CallManager-trust/Cisco_Manufacturing_CA.pem
CallManager-trust/Cisco_Root_CA_2048.pem
CallManager-trust/a0440f4c.0
CallManager-trust/a69d2e04.0
CallManager-trust/f7a74b2c.0
CallManager-trust/dcc12642.0
CallManager-trust/0d40b14e.0
CallManager-trust/CAPF-7EC94D72.pem
CallManager-trust/CAPF-97FA3FDE.pem
CallManager-trust/CAPF-e09c40eb.pem
CallManager-trust/3e92ebd9.0
CallManager-trust/8eb380b0.0
CAPF-trust/CAP-RTP-001.pem
CAPF-trust/CAP-RTP-002.pem
CAPF-trust/Cisco_Manufacturing_CA.pem
CAPF-trust/Cisco_Root_CA_2048.pem
CAPF-trust/a0440f4c.0
CAPF-trust/a69d2e04.0
[1mPress <enter> for 1 line, <space> for one page, or <q> to quit [0m
[KCAPF-trust/f7a74b2c.0
CAPF-trust/CAPF.der
CAPF-trust/CAPF.pem
CAPF-trust/dcc12642.0
CAPF-trust/8eb380b0.0
admin:utils service list
Requesting service status, please wait...
System SSH [STARTED]
Cluster Manager [STARTED]
Service Manager is running
Getting list of all services
>> Return code = 0
A Cisco DB[STARTED]
A Cisco DB Replicator[STARTED]
Cisco AMC Service[STARTED]
Cisco AXL Web Service[STARTED]
Cisco Bulk Provisioning Service[STARTED]
Cisco CAR Scheduler[STARTED]
Cisco CAR Web Service[STARTED]
Cisco CDP[STARTED]
Cisco CDP Agent[STARTED]
Cisco CDR Agent[STARTED]
Cisco CDR Repository Manager[STARTED]
Cisco CTIManager[STARTED]
Cisco CTL Provider[STARTED]
Cisco CallManager[STARTED]
Cisco CallManager Admin[STARTED]
Cisco CallManager Attendant Console Server[STARTED]
Cisco CallManager Cisco IP Phone Services[STARTED]
Cisco CallManager Personal Directory[STARTED]
Cisco CallManager SNMP Service[STARTED]
Cisco CallManager Serviceability[STARTED]
Cisco CallManager Serviceability RTMT[STARTED]
Cisco Certificate Authority Proxy Function[STARTED]
Cisco Certificate Expiry Monitor[STARTED]
Cisco DRF Local[STARTED]
Cisco DRF Master[STARTED]
Cisco Database Layer Monitor[STARTED]
Cisco Dialed Number Analyzer[STARTED]
Cisco DirSync[STARTED]
Cisco Extended Functions[STARTED]
Cisco Extension Mobility Application[STARTED]
Cisco IP Manager Assistant[STARTED]
Cisco IP Voice Media Streaming App[STARTED]
Cisco License Manager[STARTED]
Cisco Log Partition Monitoring Tool[STARTED]
Cisco RIS Data Collector[STARTED]
Cisco RTMT Reporter Servlet[STARTED]
Cisco SOAP - CDRonDemand Service[STARTED]
Cisco Serviceability Reporter[STARTED]
Cisco Syslog Agent[STARTED]
Cisco Tftp[STARTED]
Cisco Tomcat[STARTED]
Cisco Tomcat Stats Servlet[STARTED]
Cisco Trace Collection Service[STARTED]
Cisco Trace Collection Servlet[STARTED]
Cisco UXL Web Service[STARTED]
Cisco WebDialer Web Service[STARTED]
Host Resources Agent[STARTED]
MIB2 Agent[STARTED]
Native Agent Adapter[STARTED]
SNMP Master Agent[STARTED]
SOAP -Log Collection APIs[STARTED]
SOAP -Performance Monitoring APIs[STARTED]
SOAP -Real-Time Service APIs[STARTED]
System Application Agent[STARTED]
Cisco DHCP Monitor Service[STOPPED]  Service Not Activated
Cisco Extension Mobility[STOPPED]  Service Not Activated
Cisco Messaging Interface[STOPPED]  Service Not Activated
Cisco TAPS Service[STOPPED]  Service Not Activated
Cisco Unified Mobile Voice Access Service[STOPPED]  Service Not Activated
Primary Node =true
admin:
Perfil de seguridad Ej:para un CP-7960
-Phone Security Profile Info
Device Protocol: SCCP
Description: Migrated Profile: Sec_mode 3 Auth_mode 2
Device Security Mode: Encrypted
-Phone Security profile CAPF Info
Authentication mode: By null string
Key Size: 1024
At this forum, it says for version 5x to /7x I have simply to regenerate certificates:
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-version-50/99815-ccm-sec-cert.html
These are the doubts I have:
- Is it necessary to regenerate any certificate in first plase?, if so ¿what is the place I should follow for each certificate?
- Is it necessary to restart any service before regenerating the certificates? for version 8.0 and higher, I saw that it´s necessary to restart TFTP and Call Manager services.
- After regenerating certificates, is it necessary to create a new CTL file? If so, Do I need the two tokens we used to create CTL file at the begining?
- Regarding CAPF certificate. Do i need to push the LSC certificates to the phones? Or I just need to reset phones to do so?
Thank you in advance!
616
