how to remove digits in dialplan between 2 CME
edwarelsayegh
I have two sites every one has CME routers
i need to configure a dial plan on each side
let's say if i want to call from site A to Site B dial 088XXX
if i want to call from site B to Site A dial 099XXX
the problem is i want when i dial from site A to Site B only forward XXX digits acrooss the Trunk and remove 088 and vise versa
Kindly help
Hi.
If your user dial from site a 088XXX to site B you coul apply a translation profile to  your dialpeer from A to B could be
voice translation-rule 1
rule 1 /*088/ //
voice translation-prfile To-Site-B
translate called 1
dial-peer voice 10 voip
destination-patter 088...
translation-profile outgoing To-Site-B
session target ipv4:x.x.x.x
In your site B you could configure the same translation rule with 099 instead 088
SITE B
rule 1 /*099/ //
voice translation-prfile To-Site-A
translate called 1
destination-patter 099...
translation-profile outgoing To-Site-A
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
