09-13-2012 10:01 AM - edited 03-16-2019 01:11 PM
A user name is still showing up in the UCM directory. I believe I saw an option in the past to delete the end user by going to User Management -> End User-> Search and select the user -> delete the user. But I dont see it anymore. This user also has been hidden from the active directory
Our call manager is 8.6
sienz
09-13-2012 10:07 AM
Take a look:
A user is deleted from Active Directory but still appears in Cisco Unified Communications Manger as inactive and stays there in a delete pending state. This issue occurs in a Cisco Unified Communications Manager cluster synchronized with the Active Directory .
Complete these steps in order to resolve this issue.
Choose Cisco Unified Serviceability> Tools> Control Centre - Feature Services
Choose the IP Address of the publisher.
Restart the Cisco DirSync service.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080b14d18.shtml
"IF you enable LDAP synchronization in Cisco Unified Communications Manager Administration, you thereby configure your system to use the LDAP corporate directory as the end user directory for Cisco Unified Communications Manager. In this scenario, you cannot add or delete users in Cisco Unified Communications Manager Administration. You add and remove end users in the corporate LDAP directory. "
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmcfg/b08user.html
So try to do this procedure.
Leonardo Santana
Rate this if helps you
09-13-2012 10:38 AM
Thank you for the reply,
The user has been disabled in the AD for 4 days but it is still showing as active (LDAP Sync Status) in the CUCM. I have restarted the CUCM DirSync and it is still show up.
09-13-2012 10:40 AM
If this procedure does not resolve the issue, complete these steps:
Garbage Collection can cause this issue, so check the logs to determine if it is invoked.
Make sure that the Dirsync service is active.
Check the DirectoryPluginConfig table in the Cisco Unified Communications Manager database to see if there is an entry with pkid 54c43f99-a561-4f3a-868d-26a5547445d9.
Note: The output of the run sql select * from DirectoryPluginConfig command confirms whether the Garbage Collector pkid is present in the DirectoryPluginConfig table when the DirSync service starts.
If the pkid is not present, open a case with the TAC Service Request Tool ( registered customers only) and provide a remote support account so that TAC can update the DirectoryPluginConfig table to fix the Garbage Collection row.
Restart the DirSync service.
