Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
How to remove extra node license in CM5.1(3)
Does anyone know how to remove extra node license in CM5.1(3)?
The CM 5.1(3) cluster have three nodes of server. I had installed node license have five.
In case the cluster need to be upgrade to 6.1 version. Can user purchase three node license in 6.X version?
If it is not works, how can I remove the extra node license in CM5.1(3) before start the upgrade task to 6.X?
Thanks in advance!
Michael.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: How to remove extra node license in CM5.1(3)
Hi Michael,
You should be fine here :) The Node License only verifies how many Nodes "can" be up and running not how many "must" be up and running. When the upgrade to 6.x or 7.x is ordered the License can be adjusted then to reflect the actual number of Nodes that you require.
Hope this helps!
Rob
Hi Michael,
Hope this helps!
Rob
Hi Rob,
Thanks for your information!! It let me have a sweet dream tonight.
Thanks!
Michael.
123
