How to remove + from inbound DID - CUCM 6.1?
SIP trunk provider is delivering DID's in E.164 format prefixed with the + symbol.
Is it possible to strip the + symbol so we can deliver the calls to the proper extensions?
Application dial rule?
1 ACCEPTED SOLUTION
Re: How to remove + from inbound DID - CUCM 6.1?
Well is this a trunk into CCM or a gateway?
If its CCM, then set your significant digits on the trunk to 10, this is assuming they are delivering 11 digits in the form of "+2222222222". This would strip the leading digit of +. If its terminiated on a gateway, make a translation profile on the H323 Gateway in order to match the final 10 digits only and save it.
HTH, Please rate useful posts.
Chad
Chad
Chad, I am almost in the same boat , I need to send "+" from CCM to the Service Provider, is there a way to do it in the CCM ? . It is a SIP TRUNK.
Thanks for the quick response, that fixed it!
Re: Outbound appending the prefix of + I requested the service provider to remove this requirement as I was unable to find a workaround built into CM.
nyciscotech, are you using a the VG as an SBC gateway ?
I've been evaluating this idea of a SBC to prepend a "+" for outgoing calls, as the CCM does not allow it .
Also let me know if you had any problems with your SIP Trunk (from CCM to your SP).
thanks
aa
AA -
Using the SIP trunk terminated directly to CCM for beta testing. Will also be introducing a IPIPGW into the mix configured as H323 which will allow for better digit manipulation as well as appending the + prefix on outbound calls.
NYCT
254
