Community Member
How to remove Licence file from CUCM 6.1
Hi there,
I've uploaded a wrong Licence file into CUCM 6.1. Is there any way to remove the Licence file and swap it with the correct one?
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: How to remove Licence file from CUCM 6.1
Hi Sana,
Here are the details :)
file delete
The file delete command includes the parameters dir tftp and license. The file delete command deletes one or more files.
Command Syntax
file delete
dir tftp directory [detail]
license filename [detail]
Parameters
•dir tftp directory deletes the TFTP directory specified by directory. You cannot enter the wildcard character (*) in directory.
•license filename deletes the license file that is specified by license. You can enter the wildcard character (*) as filename to delete all the license files.
Options
•detail-Displays details
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp412067
Hope this helps!
Rob
1 REPLY
Hi Sana,
file delete
Command Syntax
file delete
Parameters
Options
Hope this helps!
Rob
741
