Community Member
How to remove Manager/Assistant setting
In evaluating the Manager and Assistance feature of CallManager 4.2(3), I configured phones for the test that place a DND (Do Not Disturb) logo on the Manager's phone. Now I want to re-use th phone but can't seem to remove this graphic from the 7940's display.
Any Help?
1 ACCEPTED SOLUTION
VIP Purple
Re: How to remove Manager/Assistant setting
See the following link.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_2_1/ccmfeat/fsipma.html#wp1072189
Hope this helps. If so, please rate the post.
Brandon
VIP Purple
Brandon
Community Member
Thanks, rather counter-intuitive...remove the IPMA services from the Assistant phone to clear up setting on the Manager phone .
I had already removed the users associated with the phones, so I had to re-create the Manager/Assistant relationship in order to remove the IPMA services.
Thanks again,
Charles
have you changed the phone button template for that phone to a normal one?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Yes, I had change the phone button template. That controls the softkeys, but the backgrownd graphic associated with the Manager/Assistant configuration was persistant. The previous post to remove the IPMA services from the Assistant phone, cleared up the residual effects on the manager phone.
thanks,
273
