How to Remove port number for SIP trunk in CME
I trying to set a SIP trunk with SIP provider, I have CME 7.1
The trunk is registered now but I can´t make calsl via SIP provider. After some debbugs sip provider's staff told me that the solution is not
not append the port in the INVITE.
Is it possible to do this?, How?
I have found some info about normalization but is relating to CM server not CME.
regards
VIP Super Bronze
what port number does your provider use for signalling? They need to provide you the port number if its different from the standard 5060..
You can then configure the signalling ports on your dial-peer as shown  in example below..where port 5081 is used here
dial-peer voice 1 voip
destination-pattern .T
session protocol sipv2
session target ipv4:10.10.10.24:5081
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Can you post the output of debug ccsip messages
Re: How to Remove port number for SIP trunk in CME
Hi aokanlawon,
thanks for your quick response, sip provider just told me that I must remove the port number in SIP INVITE message.
I attach one trace sip provider carrie out
regards
VIP Super Bronze
You need to go back to them and let them clarify what they want you to do. I dont see any thing wrong with the sip traces..So please speak to them..
Hi aokanlawon,
Do you know if it is possible to ,modifiy the message FROM
for instance if the call via sip trunk  sends
I needt to replace with:
regards
Bronze
By the sounds of it you need to configure delayed offer , this is configured under the voice service voip /  sip
175
