Community Member
How to remove user without DNS from Corporate Directory
Dear All,
i am running CUCM version: 6.1.2.1000-13 and we are integrating it with AD but there is so many users apparing in the corporate directory " services accounts "
so is there is anyway to remove them from telephones corporate directory.
Thanks in Advance.
1 ACCEPTED SOLUTION
Highlighted
Super Bronze
1) If you have all your users in the default 'Users' container or antoher OU, and the 'service accounts' OU is a different top-level OU (or is at least not inside the same OU as the users) you can point your AD integration at the Users OU rather than at the root of your domain.
2)Alternatively you could set a custom LDAP filter to filter out accounts - for example filter out accounts that don't have 'telephoneNumber' set (assuming you are using telephoneNumber, and not ipPhone for the tel number field).
See this write-up for this second option : http://www.netcraftsmen.net/component/content/article/70-unified-communications/742-axl-sql-toolkit-part-3-updating-cucm-dirsync-ldap-filter-by-example.html
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
1 REPLY
Highlighted
Super Bronze
Aaron
176
