Community Member
How to restore CUCM 6.0.1 subscriber server after hardware failure ?
Hi all,
Could anyone point me on clear scenario(documentation): how to make restore procedure for subscriber server after hardware failure ? The situation is following:
there is a cluster which consist of two nodes(publisher, subscriber). The hardware failure has happened on the subscriber(network card has broken). We've received another MCS7816 with preinstalled CUCM 6.0 as replacement .
What are exact steps to follow (any links to proper docs)? Has anyone done restore from backup after HW appliance replacement? Are there any suggestions for it (possible problems; how to avoid specific problems)?
This is production environment and I do not want to screw it up.
Thank you in advance.
1 REPLY
Re: How to restore CUCM 6.0.1 subscriber server after hardware f
a link is already provided in CCO
Replacing a Single Server or Cluster for Cisco Unified Communications Manager Release 6.1(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_1/cluster/clstr611.html
java
if this helps, please rate
java
www.cisco.com/go/pdi
758
