Bronze
How to restrict call transfer to Interior (No Geolocation) from Border (Geolocation)?
Hi all,
I would like to make very minimal changes on one of our customer's VOIP network which is already established without Geolocaitons or Logical partitioning policies.
I would like to restrict the call transfer from a border device located in Thailand to an Interior phone located in Singapore. Singapore is already existing without any Geolocation configured.
Though Cisco mentioned that LP checks will not be performed if any device is not having Geolocation assigned, is there anyway to achieve above? I have tried to configure "Interior -NONE" to "Border-Thailand" as deny but it is NOT working.
Regards...
Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
  • IP Telephony
Hi Ashok, Did you find a solution for this issue. I having the same problem and not able to find a solution for it
Bronze
Re: How to restrict call transfer to Interior (No Geolocation) f
Yes. I have found out a solution for it. In enterprise parameters, I have applied a default geolocation and default policy as deny. This way, you will be having all the devices having a geolocation assigned to them either specific geolocation at device pool or default geolocation. You can play with the policies then after to achieve any result.
Regards...
Ashok.
292
