How to restrict Single Number Reach?
Hi Everyone.
I have configured Single Number Reach for some of my 7942 IP Phones and its working appropriately.
I have two locations. For Example, HQ and Branch. Both have VOIP gateway for PSTN Calls. And I want SNR to work only if calls are originated locally (HQ-HQ or BR-BR) and it should not send the call to mobile if call is originated from other location (HQ-BR).
Please tell me if it is possible to do so?? and what r the required configuration??
Thanks in advance.
Pankaj
  • IP Telephony
1 REPLY
Hall of Fame Super Silver
Sorry, this is not possible as Mobile Connect essentially relies on shared line appearance and if you did this via CSS/Partitions the actual phone associated with the same extension would not ring either.
HTH,
Chris
256
