How to right correctly this destination pattern?
My mobile operator have the folowing number range in it's dialplan:
+7950 start 0500000
+7950 end 1499999
The problem is that i can not right the destination pattern in this way:
destination-pattern 7950[05-14].....
Is there any way to solve this problem without dividing this dial-peer in to multiple dial-peers?
Thank you.
Green
Re: How to right correctly this destination pattern?
Just one dial-peer
7959[01]...... should work or
First digit we know it must be 0 or 1
Second digit can be any digit from 0 to 9, same for the rest
The problem is that we have a range from
05 to 14.
destination-pattern 7950[01].....?
Green
Yep you can add $ at the end
Thank you.
But there is another broblem. and I will explain it this in 3 hours, if you don't mind. I have to run now, thank you anyway
163
