How to route 911 on remote site without CER
hi,
I would like to know, how does the CM knows that a 911 call comes from a specific remote site and forward the call to the appropriate gateway without using CER. If users on different sites dial 911, how can we redirect the call to the good PSTN ??
thank for you help
Bronze
Re: How to route 911 on remote site without CER
This can be accomplished through the use of route patterns, partitions and CSS. CER is not required to route the calls. Since each setup is unique there is no definitive answer to the question, but I will give an example:
PT: HQ-PSTN
PT: Phones
CSS: HQ-CSS (HQ-PSTN, Phones)
Device CSS: HQ-CSS
Line PT: Phones
Gateway CSS: HQ-CSS
Route Pattern: 911 AND 9.911
PT: HQ-PSTN
Using the method of allow on device restrict on the line for PT & CSS, any device with the HQ-CSS PT will route 911 calls out the gateway with the same CSS. This can be setup for each location as desired.
Keep in mind you have to address the gateway configuration ...
Thank you,
Jon
so if understand, I need to create a "Route Pattern: 911 AND 9.911" for each remote site and put it in an different partition ?
thanks
126
