How to see RAM on GW 2951
Hi everybody,
I have to get back all information on the GW of my costumer and i would like to know on the new generation of GW 2951, how see the good information ?
If i have this "show version",
Cisco CISCO2951/K9 (revision 1.0) with 483328K/40960K bytes of memory. <== RMA ? so 512Mo i think...
Processor board ID XXXXXXXXX
3 Gigabit Ethernet interfaces
31 Serial interfaces
1 terminal line
1 Channelized E1/PRI port
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
999936K bytes of ATA System CompactFlash 0 (Read/Write) <== Flash
Thanks you,
Matthieu
Green
Mathieu,
You are correct
Add the 2 number together
Equals roughly 512M
Alex
Regards, Alex. Please rate useful posts.
Okay !!
430
