How to select dial peer based on calling extension and destination
csco11030279
Hi all;
I have one H323 gateway and one CUCM 10.X,   as I have two groups of users A, B.
how can I configure the system to route the calles as follwoing :
Group A will use FXO 1
Group B will use FXO 2
any suggestion will be appreciated
islam.kamal
Level 10
Level 10
Hello
kindly check the below link , outgoing calls based on calling number .
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/41887-specific-fxs-call.html
please rate all useful information
Jaime Valencia
CSS/partitions and simply configure a prefix to match each DP, this topic has been discussed plenty of times before at CSC, a search would have provided the answer. Please search CSC for answers before posting.
java
if this helps, please rate
