11-07-2014 05:16 AM - edited 03-17-2019 12:50 AM
Dear Expert,
i would like to ask some question about VOIP system.
Currently i'm using C2951-CME-SRST/K9 with Card VIC2-4FXO. my concern as below:
1- Should i add 2 more card ( VIC2-4FXO) on C2951 ? becuse i need 8 CoLine . is it support total VIC2-4FXO x 3 ?
2- Currently i have one main phone ( Receptionist ) we can call Company "A"and i would like to create 2 more company on the same router , i mean that i create 2 more receptionist for Company "B"and "C", is it possible if i separate 3 main phone the same router?
Could you advice on this ? if you have sample configuration for separate receptionist please share for me ....
Best Regards,
Rechard
Solved! Go to Solution.
11-10-2014 01:49 AM
Yes you can add 2 more cards to the router and have 12 fxo interfaces in total.
11-07-2014 07:33 AM
Yes, if you need 8 lines, you need 8 FXO ports, and so on
There's nothing special about this, just configure the ephone for each secretary and then the routing of which FXOs should go to whom.
11-07-2014 04:57 PM
Dear Jaime,
Thanks for your command.
could we add 2 more card ( VIC2-4FXO) on router 2951 ? currently i'm using 1 card ( VIC2-4FXO). so total 3 card for VIC2-4FXO.
Best Regards,
Rechard
11-09-2014 06:26 PM
Dear all Expert and Jaime,
could you confirm me on card Vic2-4FX0 support 3 card on 2951?
Currently i'm using VIC2-4FXO one card, so could i add 2 more card on this router? if don't support , do we have other card that support 8 CO line ?
Best Regards,
Rechard
11-10-2014 01:49 AM
11-10-2014 06:05 PM
Dear Sreekanth,
Thank you for your advice.
i will order 2 more card.
Best Regards,
Rechard
