how to separate receptionist phone on C2951-CME-SRST/K9?
rechard_hk
Dear Expert,
i would like to ask some question about VOIP system.
Currently i'm using C2951-CME-SRST/K9 with Card VIC2-4FXO. my concern as below:
1- Should i add 2 more card ( VIC2-4FXO) on C2951 ? becuse i need 8 CoLine . is it support total VIC2-4FXO x 3 ?
2- Currently i have one main phone ( Receptionist ) we can call Company "A"and i would like to create 2 more company on the same router , i mean that i create 2 more receptionist for Company "B"and "C", is it possible if i separate 3 main phone the same router?
Could you advice on this ? if you have sample configuration for separate receptionist please share for me ....
Best Regards,
Rechard
Yes you can add 2 more cards to the router and have 12 fxo interfaces in total.
5 Replies 5
Jaime Valencia
Yes, if you need 8 lines, you need 8 FXO ports, and so on
There's nothing special about this, just configure the ephone for each secretary and then the routing of which FXOs should go to whom.
java
if this helps, please rate
Dear Jaime,
Thanks for your command.
could we add 2 more card ( VIC2-4FXO) on router 2951 ? currently i'm using 1 card ( VIC2-4FXO). so total 3 card for VIC2-4FXO.
Best Regards,
Rechard
Dear all Expert and Jaime,
could you confirm me on card Vic2-4FX0 support 3 card on 2951?
Currently i'm using VIC2-4FXO one card, so could i add 2 more card on this router? if don't support , do we have other card that support 8 CO line ?
Best Regards,
Rechard
Dear Sreekanth,
Thank you for your advice.
i will order 2 more card.
Best Regards,
Rechard
