Community Member
How to set busy tone for 2nd call on CME?
With CM, we can set busy trigger to 1 and 2nd call will receive busy trigger.
But with CME, how to set busy tone for 2nd call?
1 ACCEPTED SOLUTION
Re: How to set busy tone for 2nd call on CME?
If the ephone-dn is single line then your busy trigger is by default 1. You can set the busy trigger for a dual line ephone-dn by setting "huntstop channel."
PS: please remember to rate posts!
Community Member
I configure it for dual-line, because I need conference feature.
What is the different between 'huntstop' and huntstop channel'?
Should I enable 'huntstop channel' for each ephone-dn?
Is this correct configuration for feature that I need?
ephone-dn 1 dual-line
number 1050011 secondary 2306
label 1050011
description Kakanwil
name Kepala Kanwil
huntstop channel
Thx
241
