Community Member
How to set maximum call duration time in Communic Manager 7
is it possible to set maximum call duration time for calls? ...if it is so how??
regards
Re: How to set maximum call duration time in Communic Manager 7
CCM service parameter
Maximum Call Duration Timer
This affects ALL calls, there is no method to choose only particular calls based on anything you want
java
if this helps, please rate
java
www.cisco.com/go/pdi
in callmanager service parameter...
Community Member
hi Java,
thanks a lot,
215
