How to set no FAC name in CDR files ?
Dear Master,
I need help.
CUCM 7.0.
How to set no FAC name in CDR files, just FAC number in CDR files?
Susanto
1 ACCEPTED SOLUTION
Re: How to set no FAC name in CDR files ?
Hi!
By default FAC name is sent to the CDR files whenever you make a call that requires this type of code. For security reasons the FAC number is
not included on the CDR.
This is explained on this TAC Case collection and on the SRND:
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K11394707
--> SRND
https://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/dialplan.html
"Only the authorization name appears in the call detail records (CDR); the authorization code does not appear in the CDR."
Teresa.
If you find this post helpful, please rate! :)
Regards, Tere. If you find this post helpful, please rate! :)
Hi!
--> SRND
Teresa.
Hi!! Cant you send capture
Hi!! Cant you send capture file this case, i do not answer this TAC Case
Thanks!!
166
