Community Member
How to setting Callling Number for outbound call
I have 5000 DID number (56780000-56784999).Currently,when outbound call, the calling number is DID number, such as 56781234 etc. But, when a user with Ext. 5555 make outbound call, the calling number is 56785555 though this number can't be arrived when callback.
SO i want to make the following goal:
when outbound call,the calling number for Ext.0000-4999 should be 56780000-56784999. Other extension number shoule be 56780000(this is the PRI trunk number)
3 ACCEPTED SOLUTIONS
Re: How to setting Callling Number for outbound call
if u wanna use external mask for the phone
u have to check the box on the route pattren or translation pattren that says use external phone mask
good luck
and thanks for rating
Community Member
Hey hey... just a thought, rather then making so many translations an partitions an the like.. why not just do the translations on the route pattern or the route list? and for the 5555 etc give it its own route pattern out to the same gw would save on admin time :)
or if your running h323 do it on the gateway even easier :)
Dan
Dan idea works as well
i just given that idea because it came in my mind
all works
just find whaterver one u find it easy and practical
good luck
u can dot it in diffrent ways
u ca put each number with its DID outside number on each line in the phone setting in the external phone mask
but long way
i have simple question
in ur caase if Ext. 5555 u want it to apear as 56780000 and numbers between 0000 to 4999 apear as they are i mean the last four digits?
if this the case creat three partions P1,P2 and P3
creat two translation pattrens the matching pattren point to ur ouside pstn
and first translation pattren with partion P1 and the second P2
on the first translation pattren just change the calling number as u wan it like
5678XXXX
on the second translation pattren make the calling number transformation mask as 56780000
on both translation pattrens put a CSS that contain P3
now creat a route pattren point to pstn the same pattren match in the translation ptrrens
and make the route pattren partion as P3
on phone lines from 0000-4999 make the CSS include P1 and all other phones in thiser CSS include P2
now other phones like 5555 will call outside will match second translation pattren because they have accesss to the calling number will be translated to 56780000 and will be send to the pstnroute pattren becasue the translation pattren have access to though its CSS
good luck
if helpful Rate
Community Member
THanks sir. 5 pints for your kindnes.
I think I almost can catch you.But it seems many steps needed.
I tried to set external phone mask for 5555 as 56780000, whereas the calling number still is 56785555.
Why 'External Phone Mask' doen't work here??
good luck
Community Member
Dan
all works
good luck
133
