Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
How to setup a test lab with analogue FXO/FXS?
We are setting up a test lab for fax server software interoperability testing with cisco ISR fax-gateway (both, inbound and outbound transmissions).
The planned setup includes cisco 2801 or 3725 with network module and VIC cards. I assume that connecting FXO to FXS using RJ-11 cable will help avoiding a third party telephone line simulation equipment. Is it correct, or 4FXO with telephone line simulator is the way to go?
Hall of Fame Super Gold
Re: How to setup a test lab with analogue FXO/FXS?
Use an FXS card, to which you connect a fax machine directly.
Thanks. We need to perform stress/scalability testing and use 4FXO connected to 4FXS. 4 fax machines will be over-kill. Would our proposed setup work or not?
Four fax calls will not stress the routers at all.
Use E1 PRI for that.
294
