How to show calling extension number on 6921 or 6941
mrmhar1408
Level 4
Level 4
Dears,
I have call manager 9.1 and phones 6900 series
the phones displays the name only and doesn't display the calling extension number
is there any service parameters related to this feature.
Manish Gogna
The phone should display the calling party information by default. Is it happening for direct IP-IP calls between two IP phones on same cluster or for external calls? What is the phone firmware involved?
Manish
In my case is between clusters and in the same cluster.
Best regards,
Igor
Some of those phones simply cannot display all the info due to the small screen they have, there's nothing to do about it, that's how they work.
java
if this helps, please rate
Ok, thank you Jaime! I think this is a step back from cisco with this phone model. Just replaced 100 phones 7911 per 6921 :(
