how to support 802.1x guest vlan behind ip phone?
I have configured 802.1x and voice vlan ,guest vlan on my switch ,but guest user can not enter guest vlan ,it always prompt "dot1x-ev:dot1x_guest_vlan_applicable: Guest VLAN not applicable. Supplicant disabled and EAPOL seen on port FastEthernet0/21."
interface FastEthernet0/20
switchport access vlan 201
switchport mode access
switchport voice vlan 1
dot1x pae authenticator
dot1x port-control auto
dot1x max-req 1
dot1x max-reauth-req 1
dot1x reauthentication
dot1x guest-vlan 202
dot1x auth-fail vlan 202
spanning-tree portfast
if I enable "dot1x host-mode multi-host" ,my 802.1x user can not be authorized ,it prompt "1d00h: dot1x-ev:dot1x_guest_vlan_modify_host_mode: Guest VLAN feature overriding host_mode on port FastEthernet0/21, forcing to DOT1X_MULTI_HOST"
interface FastEthernet0/21
dot1x max-req 1
end
Anyone have some advise ?
1 REPLY
Re: how to support 802.1x guest vlan behind ip phone?
I recently got the answer for this on this forum. you need to have following global config command in your switch.
"dot1x guest-vlan supplicant"
Because the switch received EAPOL-Start from the PC it won't get the guest vlan. However, because the PC doesn't have the Cert it won't reply to EAPOL-Id-Request from the switch. So as this not realy a Auth-fail the PC won't even get a Auth-fail vlan.
The above command should allow the switch to put the port in Guest VLAN.
Anand
403
