07-16-2007 11:16 PM - edited 03-14-2019 10:36 PM
There are 2 MCS 7845 configured as CCM cluster. Each 7845 come with 2 NICs. How can I team these 2 NICs as a virtual one worked as active/standby mode ?
Solved! Go to Solution.
07-17-2007 09:26 PM
With CM 5.X on a supported MCS HP Server this will work.
-You will have to ssh in or be on the console directly
-You enable it from command line on the server
-set network nic failover ena
-You will need to reboot the cluster
-Next, show status
-show network failover
Please refer to the link below for further information.
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_im
plementation_design_guide_chapter09186a008063743a.html#wp1070947
Due to driver issues we don't support NIC teaming on IBM platforms as of
now.
07-17-2007 09:26 PM
-Next, show status
now.
08-27-2007 05:18 AM
Any idea when teaming will be supported on the IBM platform? I have a 7825 I2.
08-27-2007 01:20 PM
I know it works on 7835-I2 on 5.1
